It is currently Wed Jul 30, 2025 5:16 pm
 Post subject: Re-sizing wooden dowels
PostPosted: Wed Feb 12, 2020 6:42 pm
When I need to re-size a dowel, I take a piece about 8" long and chuck it up in my cordless drill. I use my metal drill gauge to reduce it down to the size I need. I sharpen the end of the dowel, so that I can start it in the hole size that is 1 step smaller than the dowel. I lay the drill gauge over a hole that is in my work table, and run the dowel through the hole in the drill gauge. It will grind it down in a jiffy. Work your way down 1 size at the time, and you can take it down to any size you need. You also can do a step down in the dowel if needed. Below is the type drill gauge I am talking about. You can find them for cheap at most hardware stores.
https://www.grainger.com/product/39EP32?gclid=EAIaIQobChMI1ufUy5jN5wIVhYbACh1xmwWpEAQYAyABEgI-mfD_BwE&cm_mmc=PPC:+Google+PLA&ef_id=EAIaIQobChMI1ufUy5jN5wIVhYbACh1xmwWpEAQYAyABEgI-mfD_BwE:G:s&s_kwcid=AL!2966!3!284662604830!!!g!478234114501!
These users thanked the author guitarjtb for the post (total 3): Pmaj7 (Thu Feb 13, 2020 12:01 am) • Ed Haney (Wed Feb 12, 2020 8:14 pm) • Terence Kennedy (Wed Feb 12, 2020 6:43 pm)
PostPosted: Wed Feb 12, 2020 8:14 pm
Last Name: Haney
City: Sugar Land (Houston)
Zip/Postal Code: 77479
Nice tip, James. Thank you.
PostPosted: Wed Feb 12, 2020 9:21 pm
That is how I make mahogany dowels for filling headstock screw holes, except I use the metal holders in the drill bit box...
PostPosted: Wed Feb 12, 2020 10:10 pm
City: U.P.
I gotta try that, thanks!
Brian R, Wood Mechanic
N8ZED
